transaxle fluid
Has anyone had to replace the transaxle fluid in their monte?? It says in the manuel that if you drive in a city that is consistently more than 90 degrees you shuold change it at 50 miles. Anybody have any idea how hard it would be to do yourself or how much it would be to take it somewhere?
RE: transaxle fluid
50 miles wow! :(
RE: transaxle fluid
yaknow i dont think i have ever actually done it my self on purpose. most of the time i have had to do it when im changing the axels on a car.
but for the most part it was not to difficult. each car was diffrent on what oil/fluid to use and also how to put it in. Some were a part of the normal tranny fluid and filter systems. others were non maintnace style |
RE: transaxle fluid
I change my tranny fluid and filter every 60K. Its not hard but messy you have to drop the pan. PS I have never had a transmission failure and doubt I ever will as long as the fluid is clean and the filter is clean because the transmission is just a Hydrualic pump!
RE: transaxle fluid
I change my tranny fluids and keep them up. i changed it a coupel of times now i have a shift kit in the car i make sure it is done!! want to make sure it dose not screw up
RE: transaxle fluid
Never changed transaxle fluid until the boots have broken.
Never have been told or advised to other than after boot leakage. |
RE: transaxle fluid
yeah umm SS. it is defently a good i dea to have it done at least once in a while on your car so tha tthe fluid in there is not wore out or carring a bunch of floaties LOL
RE: transaxle fluid
I am a very anal person, so I change mine every 30,000 miles. The fluid is not hard to change and what's even better is that onmost late model cars that have the 4T65-E tranny, the gasket is reuseable. When changing the fluid, it is also good to change the filter. If you really want to go all out, do what I did and buy a transmission pan with a drain plug in it. The one I bought has this along with cooling fins to keep the fluid a bit cooler.
If you are going to change the fluid, be aware that GM is recommending the use of DEXRON VI in cars that previously used DEXRON III. Although it doesn't really matter,it is best tohave your transmission flushed to rid it of DEXRON III so that there will be only DEXRON VI in there. It is, however, ok to mix both types. Here are the upgrades from DEXRON III: Clutch Friction Stability Improved 100% Clutch Durability Due To Fluid Improved 120% Oil Film Thickness Increased 20% Fluid Oxidation Improved 100% Foam/Aeration Improved 150% Shear Stability Improved 200% |
