Trans problem (Urgent)
Old Jun 2, 2009 | 01:15 AM
Weber's Monte's Avatar
Originally Posted by MAMONTE
I'm not sure how hard its shifting obviously, but, my 06 LT 3.5L has always since the day I bought it shifted somewhat hard...Nothing to be concerned about, but you feel the shift, it just feels like its slightly performance tuned or something...
Like I said, I don't know how hard your is shifting, but I do know that a firm shift is normal for our cars.
If your still under warrently, I would have it checked out..
Also, when you had it flushed, are you 100% sure that the place you had do the work flushed your tranny with Dexron VI? ALL 2006 and newer GM cars and trucks REQUIRE the use of Dexron VI transmission fluid. If the flush shop did not use the correct fluid, and used Dexron III fluid, this could be your problem. The new fluid has a lighter viscocity than the old stuff, and is a semi synthetic fluid with new friction additives. Personally, I change my own tranny fluid, and I know Dexron VI is not the easiest fluid to find, so I would be suspicious that the tranny place you had flush the fluid, used the older Dexron III.
Anyway, just a thought...Good Luck
it shifts almost violentley (hard thud)
Old Jun 2, 2009 | 01:16 AM
Originally Posted by PINKFLOYD_
Be careful about flushing it too much. I would get it scanned first.
had it scanned and she passed
Old Jun 2, 2009 | 12:03 PM
MAMONTE's Avatar
Hmmm....Yea mine is not violent at all, just nice and firm, the way it should be...
I don't know of a way to test the fluid type, only thing I can recommend is flushing it out using Dexron VI fluid, that way you know for sure its the correct fluid, and go from there.........
Old Jun 7, 2009 | 05:46 PM
Talked to a tech i know and he said that its probally a fluid pressure valve that is sticking.
Old Jun 7, 2009 | 06:12 PM
MAMONTE's Avatar
How expensive is that to fix???
Old Jun 8, 2009 | 03:50 PM
Not to shure yet but today i changed the oil and examined the fluids and found my transmission fluid to be over the mark (the engine was running and it was on a lvl surface) I wondering if the transmission problem is related to that but the problem only happens when the transmission is good and hot (aprox 30/45 min). So im wondering if when the transmission is up to temp the fluid is thinning out and might just turn out to be way to much fluid.
Old Jun 8, 2009 | 06:07 PM
MAMONTE's Avatar
Well, was your tranny fully warmed up when you checked the fluid?
You are right in the sense that you must check tranny fluid while car is level and running, but you also need to have the transmission up to full operating temp....I usually check mine after I get home from work or something where I just drove it for a little while...
Old Jun 9, 2009 | 02:46 AM
Im not totally shure if it was up to full temp but it was dam close but you think that it is plauseable?
Old Jun 9, 2009 | 02:49 AM
is there a way to remove the excess fluid without removing all the fluid
Old Jan 30, 2010 | 06:31 PM
joedaslik's Avatar
Looking to flush my own tranny fluid...Does the transmission have a permanent filter?
