Tranny Fluid Dripping From Tubes Going into Tranny
Old Feb 1, 2009 | 10:08 AM
slinkeey's Avatar
Default Tranny Fluid Dripping From Tubes Going into Tranny
Hello,
I was changing the oil on my 2006 Monte and I couldn't help to notice a droplet of tranny fluid hanging from the tubes that go into my transmission.
I do see that there is a nut on it if I push the black cap back.. Should I try to give the nut a little turn to see if it compresses a seal tighter?
Jeff
Old Feb 1, 2009 | 10:48 AM
sonin66's Avatar
Default RE: Tranny Fluid Dripping From Tubes Going into Tranny
wont hurt
Old Feb 3, 2009 | 10:33 AM
Dale3goodwrench's Avatar
Monte Of The Month -- March 2009
On my 2004 SS there are no nuts holding the lines in the tranny or the radiator. I had a line leaking also. The lines are held in by little C clips. Just so you know the new line from the Chevy dealer was only $16 if I remember right. Not hard to replace at all.
03vaderSS
Feb 18, 2015 02:46 PM
85ssmonte355
Nov 17, 2014 04:24 PM
Tadcaster
Jan 22, 2014 08:01 PM
Enzo354
Aug 8, 2011 12:08 PM
