Tranny Fluid Dripping From Tubes Going into Tranny
Hello,
I was changing the oil on my 2006 Monte and I couldn't help to notice a droplet of tranny fluid hanging from the tubes that go into my transmission.
I do see that there is a nut on it if I push the black cap back.. Should I try to give the nut a little turn to see if it compresses a seal tighter?
Jeff
Jeff
On my 2004 SS there are no nuts holding the lines in the tranny or the radiator. I had a line leaking also. The lines are held in by little C clips. Just so you know the new line from the Chevy dealer was only $16 if I remember right. Not hard to replace at all.
85ssmonte355
Nov 17, 2014 04:24 PM
