6th Gen ('00-'05): Trac Off Light.....
Old Feb 4, 2018 | 07:32 AM
michelob's Avatar
Default Trac Off Light.....
So I changed out my Trac Off control button by the shifter with a brand new AC/Delco one and it worked fine for about a day. Now my Trac Off light is illuminated on the dash AND I have no brake lights?!?!
Any suggestions?
P.S. I will point out that the ABS light is NOT on....
Old Feb 4, 2018 | 09:17 AM
michelob's Avatar
*SOLVED*
So I started checking fuses and changed the ABS/PCM 10A fuse (driver side). Checked the passenger side BRK SW 15A fuse.....and there was a 2A fuse in it?!?! No idea how that got in there LOL. So I changed out both fuses and all is good now.
Old Feb 10, 2018 | 05:33 PM
michelob's Avatar
Need some help again I thought this was fixed....but its not. The BRK SW (I assume the brake switch) 15A fuse keeps blowing. I noticed one time it blew when I was stuck in the apartment parking lot and the traction control kicked in. The other time it blew when I had the hazard lights on. What would be causing this? Obviously a short somewhere? Is there a common area or place I can check? I'm gonna take it in next week as I'm tired of changing the fuse out all the time.
Any help is much appreciated if its something I can fix myself? Thanks guys.
