Tick, tapping, sound when I'm turning with no accelerator
Old Feb 21, 2010 | 10:29 PM
irulesoha's Avatar
Default Tick, tapping, sound when I'm turning with no accelerator
Yep.
When I'm turning with the foot off the gas I hear, and kind of feel, a light tapping going on somewhere under the hood. Only when I turn, and only when I don't have the accelerator down at all.
Any thoughts?
Old Feb 22, 2010 | 12:30 PM
RickAKATed10's Avatar
Photobucket
I'm not sure what the cause is, but I've kind of noticed a click noise/feeling when I turn, but that's when the car is in motion and it only happens occasionally. I actually think there is a TSB regarding it, but I could be wrong.
Old Feb 22, 2010 | 12:42 PM
ISS issue makes a nice click you can hear and feel while turning.
Old Feb 22, 2010 | 01:01 PM
Photobucket
I'm pretty sure I have this going on right now. So... Just take it to the dealer, right? Any specific problem code I should bring up?
Old Feb 22, 2010 | 01:16 PM
Just tell them your intermediate steering shaft is giving you problems and if there is still the warranty etc to fix it.
If not you can grease it yourself and have it "fixed" in 5 minutes.
Old Feb 22, 2010 | 01:54 PM
Photobucket
Well then...
Old Feb 22, 2010 | 01:56 PM
Drop the plastic cover with the 2 clips that is above your brake / gas pedal. Pull back on the black rubber boot and near the greenish / teal circle you will see the knuckle.
Shoot that with white lithium grease, turn your steering wheel, shoot it with more grease, put back together.
Old Feb 22, 2010 | 02:20 PM
Photobucket
That's seriously where the clicky feeling is coming from? It isn't a front end thing?
Old Feb 22, 2010 | 02:21 PM
That's where you fix your ISS, if it is indeed your ISS.
Had the clicking in the steering wheel myself, now each spring I just shoot that with some gun oil.
Old Feb 23, 2010 | 11:15 PM
Sliver's Avatar
Let's not forget cv shafts. Clicking while turning is their signature. In my esxperience, the ISS is almost felt more in the steering wheel as clunking than it is a clicking. Just from my experience though.
