Temperature problem
Old Jan 24, 2013 | 08:45 AM
M.C. Rider's Avatar
Default Temperature problem
I have a 02 Monte Carlo and having problem with the temperature . When in park the temperature goes up but when I start to drive it ...it start to fall and little heat is coming out. It takes me to drive it for awhile for it to stay up . But only do this when the temperature in the low 30s and 20s.Please help I'm freezing going to work in the morning....here in Indiana
Old Jan 24, 2013 | 08:48 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
To me it sounds like you don't have a thermostat in your car. That won't really hurt anything in the summer, but in the winter time, you need one. I would first check to make sure that one is installed. If not, put one in. Another problem could be that your thermostat failed in the open position. Same fix. Just replace the broken one with a new one. They are very cheap and easy to do. Good luck!
Old Jan 24, 2013 | 08:49 AM
Sounds to me like a stuck thermostat...
Especially in colder tempatures.../ Its stuck closed or clogged..whens the last time you did and cooling system maintenance?
You may even have a faulty/ bad water pump.. Or something as simple as a bad radiator cap!
Whens the last time you checked the radiator fluid...????
Old Jan 24, 2013 | 08:54 AM
Sounds to me like there could be air in the cooling system. Get it flushed and change the thermostat
Old Jan 24, 2013 | 09:06 AM
M.C. Rider's Avatar
I had to replaced thermostat last winter but maybe its gone bad again.Yes I check the fluid and it was ok had to put alil in but it was top off. But the air in the coolin system that I need to check. Hope that is the problem ...going to check that and I update you guys let you know how that work out. Thanks 4 the info it real helps
Old Jan 24, 2013 | 12:33 PM
03SSLE's Avatar
I agree with making sure the system is full (no air pockets) and that the thermostat isn't malfunctioning, but when ambient temperature gets <20° what you are describing could be considered 'normal'.
fordwhupper
Oct 25, 2016 06:19 PM
SmokeytheBear75
Apr 15, 2008 08:21 AM
hckygoalie31
Aug 28, 2007 06:44 PM
breman
Sep 27, 2006 09:01 PM
04MonteLS
Jun 6, 2005 11:18 PM
