Temperature guage off-set
Hello all and thanks for reading,
My Car: 2001 LS 3.4L ( I think) The temperature guages seems to funtion correctly (it will rise/fall with engine heating/cooling), but it is way off-set. Normally it operates around the 180- 190 range, but now it operates well below where any numbers are. I have had this apart in the past so I'm sure I did it, but now I have it all off an I'm trying to maually set the needle higher (to the correct range), but as soon as I turn the key, it goes back to the range which would be round -300 (if there were numbers there). Any ideas??? Sorry if this is confusing and thanks ahead of time if anyone can help, Shaper |
Stepper Motor went bad.
Check the how-to section |
