Temperature control
Old Mar 23, 2011 | 05:24 PM
nutgump's Avatar
Default Temperature control
I have a 01 monte carlo. The temperature is stuck on heat. When I turn **** to blue for cold it stays hot. Do I have to replace temp control switch or check out somethingelse. If I do have to repl switch, how hard is it, and how do I do it. I've already taken dash apart to get instrument panel out to replace lights out a few years ago.
Old Mar 23, 2011 | 07:31 PM
Justin Knight's Avatar
the temp door motor could be faulty or the door itself could be stuck in the hot position if it hasn't moved since its been cold out. the hvac control heads are pretty reliable in the W-body cars.
Jul 8, 2012 08:27 AM
hckygoalie31
Aug 28, 2007 06:44 PM
smolek37k
Nov 4, 2006 04:36 AM
breman
Sep 27, 2006 09:01 PM
04MonteLS
Jun 6, 2005 11:18 PM
