Success story code P0102
Old Jun 14, 2014 | 01:22 PM
glasspilot's Avatar
Default Success story code P0102
Over a month ago I had the SES light come on. I've seen this light very little in the 15 years I've owned my Monte.
My friend had a reader; it showed P0102: "Mass Air Flow circ. low input" Now, I know enough not to just slap a new MAF sensor in there. A new one costs over $100. So, I'm kinda **** about researching a problem, and the car was drivable so I took my time. I did remove the throttle body and cleaned it and the throttle plate. It was pretty nasty, especially behind/downstream. Removed and cleaned the EGR valve, new gasket. The Throttle position sensor is pretty easy to test with a multimeter so I did that, it passed. The Idle control valve was only $30 so I threw one at it. Problem still there. There is a good web site that tells how to test sensors, but to test the MAF you need a multimeter that can read Hz. One site even said a bad ground to the PCM could cause this so I removed the PCM and cleaned all.
I finally broke down and bought a reman Cardone MAF at my local Auto Zone. With fingers crossed I installed it. Wa-La! Driving for almost a week now, the light is out and the 199,600 mile engine runs and idles just great. I thought you'd all want to hear a success story!
1999 Monte Carlo Z34
Old Jun 14, 2014 | 03:24 PM
ohara's Avatar
Congratulations, glad to hear you got it figured out, and from the sounds of it you did some great maintenance work on your car during the process.
Last summer I had to replace both my egr valve and MAF sensor, they both died within a fairly short time of each other, it was kind of aggravating during the process but in the end it is a nice feeling knowing you have new parts under the hood
again glad you got it figure out
Old Jun 19, 2014 | 12:31 PM
glasspilot's Avatar
A week and all is still well! Engine starts, idles and runs well. No check engine light! Just about to turn 200,000 miles.
Old Jan 4, 2015 | 10:49 AM
avendo's Avatar
I just got that code today,i already cleaned the maf,it looks already replaced,egr valve,is the the little module standing up on right rear of eng?
Old Jan 4, 2015 | 04:45 PM
ohara's Avatar
yes depending on which way your looking at the engine lol, two bolts hold it on and takes under 5 minutes to replace. Odds are you will be able to re use the paper gasket that is on there, but definitely give it a good once over before just in case. I just picked a used one up at a wreckers for under 20 bucks and it has been working great since
Old Jan 4, 2015 | 07:24 PM
glasspilot's Avatar
I see somebody resurrected this thread. The fix I did still good, over 205,000 and all's well!
Old Jan 4, 2015 | 07:36 PM
owens91's Avatar
thats good, i replaced mines with some aftermarket before and it crapped out on me less than a year later, i got a AC delco replacement and i havent seen it yet fingers crossed
Old Jan 5, 2015 | 05:03 AM
avendo's Avatar
I cleared the 102 code last night and 20 min ride to work and its back on????
Old Jan 5, 2015 | 05:18 AM
avendo's Avatar
I finally broke down and bought a reman Cardone MAF at my local Auto Zone. With fingers crossed I installed it. Wa-La! Driving for almost a week now, the light is out and the 199,600 mile engine runs and idles just great.so you have it working ok with a REMAN MAF...i been reading that this is not common.
Old Jan 5, 2015 | 09:23 AM
avendo's Avatar
http://www.direction.com/products/air-flow-meter-one
Real ac delco?
