6th Gen ('00-'05): Stuttering issues W/3800 series II
Old Nov 12, 2016 | 03:59 PM
Sadsap's Avatar
Awaiting Email Confirmation
Default Stuttering issues W/3800 series II
Hello, So I have joined this page because I have had the most difficult time trying to figure out a problem I have had these past 6 months. My car is a 2002 SS with its second 3800 series II engine. The total mileage on the car is 280k and the engine itself is roughly 175-200k. When I am driving and I get up around 3000 rpm the car stutters, if I keep stomping on the accelerator, it jerks back and forth and speed does not increase (which isn't a wise thing to do, but I am desperate to solving this problem lol). I thought it was transmission, but Autozone scanned it and said it was intake manifold. Mechanic said its Mass Airflow Sensor and fuel filter($460). Then I have my friend says it is my transmission. If you would like me to make a video, I can arrange that. Thanks so much!
Old Nov 12, 2016 | 04:26 PM
WBody's Avatar
Last time for basic maintenance? Bad spark plugs cause problems similar when under load. Wouldn't hurt to make a video.
Old Nov 12, 2016 | 04:41 PM
Sadsap's Avatar
Yes they have been changed. But I would like to mention one major detail I have left out, The stuttering only happens when the air is on.
Old Nov 12, 2016 | 04:44 PM
Sadsap's Avatar
I will get you that video later tonight.
Old Nov 12, 2016 | 06:01 PM
WBody's Avatar
a/c? That's extra load too. What brand spark plugs?
Old Nov 12, 2016 | 06:54 PM
Sadsap's Avatar
Yes and ACDelco
Old Nov 12, 2016 | 06:58 PM
Sadsap's Avatar
I also heard someone tell me that it is the fuel filter.
Old Nov 12, 2016 | 09:25 PM
WBody's Avatar
Remember the gap/which one you put in? Do you do any work yourself?
Fuel filters, like spark plugs, fall under maintenance - if you haven't done one in a while or cannot remember, it's a cheap part to replace and I'd say do it.
But earlier you posted telling you had already had it replaced. How long ago?
I'd say there is a misfire causing a stumble. I'd get the car scanned again. Maybe with a better scan too - one that can show live data and see stored codes.
Old Nov 13, 2016 | 10:52 PM
nitehawkjcb's Avatar
Bad MAF could definitely do it. Or a nasty vacuum leak. Perhaps an intake manifold gasket leak. Or any number of other things. I would suspect the transmission last, based on the info given. Codes are good to have, and you need to know exactly which codes are being thrown...
Old Nov 14, 2016 | 01:57 PM
ShelteredMule's Avatar
Could be a bad MAF sensor or ignition coil. I had that problem and my check engine light would flash when it did it and set a code for a misfire. I swapped a couple coils and the misfire moved and that's how I knew which coil it was.
