studdering
Old Jan 17, 2015 | 03:16 PM
avendo's Avatar
Default studdering
well another prob,tried to pass on the highway and the car is like a plugwire fell off,can torque the car to 2 k and then it shakes and I got 19+ vacuum got the p0171 code earlier...it idles fine....what now?
Old Jan 17, 2015 | 05:08 PM
Heres a list of things that cause this code.
My Moneys on Bad MAF... (NON AC Delco)
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty
    Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor
  • Possible cracked vacuum or PCV line/connection
  • Faulty or stuck open PCV valve
  • Failed or faulty oxygen sensor (bank 1, sensor 1)
  • Sticking/plugged or failed fuel injector
  • Low fuel pressure (possible plugged/dirty fuel filter!)
  • Exhaust leak between engine and first oxygen sensor
Old Jan 17, 2015 | 06:44 PM
avendo's Avatar
The MAF (Mass Air Flow) Sensor is dirty or faulty---just replaced and new reg filter
Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.There could be a vacuum leak downstream of the MAF sensor-19+ in vacuum
Possible cracked vacuum or PCV line/connection--
Faulty or stuck open PCV valve --cleaned pcv
Failed or faulty oxygen sensor (bank 1, sensor 1)-- new O2sensor
Sticking/plugged or failed fuel injector---possible 3 cans of cleaner-
Low fuel pressure (possible plugged/dirty fuel filter!)--fuel filter would not do 1 bank only
Exhaust leak between engine and first oxygen sensor-no exhaust leaks
Old Jan 17, 2015 | 07:03 PM
Maf Replacement..
Was it an AC Delco?
If not..Maybe its the problem?
Have you tried unplugging the MAF and then drive it to see if it runs better?
If not...
I would try Spraying WD40 in and around the vacuum line PCV and see if the idle changes...
If the idle does change...Then It could be a vacuum leak
Maybe a bad PCV valve..
Old Jan 18, 2015 | 06:27 AM
avendo's Avatar
I will try unplugging it and see...pcv valve wasn't clogged,i have been spraying spots for leaks..
Old Jan 18, 2015 | 08:36 AM
avendo's Avatar
Unplugged it and same thing... Throttle position sensor? Crank position sensor?
Old Jan 18, 2015 | 10:58 AM
avendo's Avatar
the plugs look kinda ratty..it has autolites #606..think that can do it?
Old Jan 18, 2015 | 01:25 PM
avendo's Avatar
Old Jan 18, 2015 | 01:36 PM
avendo's Avatar
the hose going there had a plastic elbow that broke and car was running crappy with it after I just changed plugs.
Old Jan 18, 2015 | 06:44 PM
avendo's Avatar
there is a connection that connects to the side of the egr valve and goes to the back of the engine,i sprayed wd in there and the eng died...weird spot, I put silicone in there,hope that fixes it.
