Stock Air Box
Old Jul 8, 2007 | 05:13 PM
drayven's Avatar
Default Stock Air Box
Hi
I just replaced my air filter with an after-market one. While taking out the stock air box I noticed it comes appart in 3 pieces. I removed the first two but the third piece (closest to the headlights) is still there. There seems to be some electronic component mounted to the air box with wires. I didnt want to remove it as I am not sure what it is. Please help
Cheers
Peter
Old Jul 8, 2007 | 05:25 PM
06LT3's Avatar
Default RE: Stock Air Box
Your replacing the air filter? or the whole Air box, like a cold air intake? lol whats the question?
Old Jul 8, 2007 | 07:03 PM
DESS03's Avatar
that woud be your pcm (powertrain control module)
Old Jul 8, 2007 | 07:04 PM
drayven's Avatar
lol the whole air box. I tried to remove it today. when i was i noticed a grey rectangle shaped block with wires coming out of it. This was attached to the stock box. I was wondering what it is and if it can be removed. Thanks
Old Jul 8, 2007 | 07:05 PM
drayven's Avatar
ohhhhh. lol i guess that would be important. For you guys that have done a complete air intake replacement, did you completely remove the stock box and if so where did you relocate the pcm?
Old Jul 8, 2007 | 10:58 PM
HyperFox's Avatar
Hmm. Some people use a manufacutred bracket to hold the PCM on a set of rubber buffers. The K&N Filtercharger encorporates this.
Old Jul 8, 2007 | 11:07 PM
2000LS's Avatar
i belive the number for gms pcm tray is 15995679 its about $10 from gmpartsdirect, but then its about $10 more ontop of that for shipping and handling.... or probly around $20 from any gm dealer
Old Jul 9, 2007 | 07:32 AM
wiz kidd's Avatar
yah, if your doing a cold air intake, then the k*n one comes with a bracket for that computer, but if your building your own then you have to fabricate something for that
Old Jul 9, 2007 | 06:29 PM
drayven's Avatar
Good to know. Thanks all. I will contact my local dealer.
Cheers
Peter
Old Jul 10, 2007 | 12:59 AM
natedawg0613's Avatar
another option instead of going through the factory not sure how much they charge
http://www.wbodystore.com/grandprix/pcm-tray-p-151.html
