Starter relay
Old Sep 11, 2015 | 09:08 PM
Rooster13's Avatar
Default Starter relay
I am trying to solve a problem but not sure where the starter relay is located. Help please and thanks.
Old Sep 17, 2015 | 09:06 PM
plumbob's Avatar
Please let us know what year and model your car is.
Old Sep 18, 2015 | 04:59 PM
Rooster13's Avatar
Sorry, I found it, My Monte is a 04 SS. I have googled my problem and it seems to be one that a lot of people with Impala's and Monte's have been having and dealers have no idea what the solution is.
Old Sep 18, 2015 | 05:36 PM
plumbob's Avatar
Is it the ignition Passlock problem?
Please let us know what you find.
Old Sep 18, 2015 | 07:07 PM
Hemivette's Avatar
Sounds like an ignition switch. Can you get it turn over with a screwdriver? h
Old Sep 20, 2015 | 09:46 AM
Rooster13's Avatar
The problem is that the car leaves my wife stranded some where and by time I get off work hours later and go to check it out it starts right up. She says the security light has been coming on lately. I replaced the starter relay and I am waiting to see what happens next. Dealer has no clue what the problem is and I am not going to let a dealer go through process of elimination at my cost to solve a wide problem which other owners are having also. I am an old hot rod guy but any thing with a computer I am clueless. Thanks, Rooster.
Old Sep 20, 2015 | 01:33 PM
Hemivette's Avatar
That sounds like a CPS going bad. They developed a crack, and when they are cold they start right up, but when they warm up it expands, and fills with oil, resulting in a no start condition. When its doing it, does the engine turn over? Not sure if newer models are the same, but my 97 had a security issue, and the starter wouldn't even turn over, when it was giving me problems. h
Old Sep 22, 2015 | 08:25 PM
Rooster13's Avatar
Engine does not turn over at all.
Old Sep 23, 2015 | 12:37 PM
Hemivette's Avatar
Sorry, I naturally assumed, if it left her stranded, she was able to start it? Does she have it towed somewhere, then call you to say she's stranded? h
Old Sep 25, 2015 | 02:54 PM
Rooster13's Avatar
She was always stranded but was able to leave vehicle there, when I show up hours later it will start right up. Even a dealer that we drove it to could not give a reason for this happening although they had a Grand Prix there doing the same thing.
