7th Gen ('06-'07): SS staying on after its turned off
Old Jan 11, 2017 | 07:26 PM
Maniac's Avatar
Default SS staying on after its turned off
My check engine light came on and got the code p1682 for a faulty engine switch and when I turn the car off and take the key it it stays on for about 1-5 minutes
Old Jan 11, 2017 | 07:30 PM
Maybe this will help you.
I got this from a code site-->P1682 Chevrolet Ignition 1 Switch Circuit 2 OBDII Engine Light Trouble Code | Engine-Codes.com
Possible causes
- Faulty ignition switch
- Ignition Switch harness is open or shorted
- Ignition Switch circuit poor electrical connection
- Faulty Engine Control Module (ECM)
When is the code detected?
The ECM has detected a voltage difference between two circuits
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible no crank or start
P1682 Chevrolet Description
There are 2 ignition 1 voltage circuits supplied to the Engine Control Module (ECM). The first ignition circuit is provided by the powertrain relay, through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The second ignition 1 voltage circuit is supplied by the run/crank relay through a fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the 2 ignition 1 voltage circuits, DTC P1682 will set.
Old Jan 11, 2017 | 07:38 PM
Maniac's Avatar
Yeah I got it from there also, but I replaced the fuses and it's still doing the same thing
Old Jan 11, 2017 | 07:54 PM
Hopefully someone else who has had this issue will respond.
Sorry I could not help more
Old Jan 12, 2017 | 12:18 AM
Looks like your buying a new ignition switch. If only you were Turbo, this could be a good thing as it is mimicking a turbo timer...
Old Jan 12, 2017 | 08:23 AM
Maniac's Avatar
Yeah, that's what my buddy and I were saying. But I don't think it's good with a non turbo lol
Old May 29, 2022 | 05:51 PM
Lafayette's Avatar
Was this issue resolved ? If so what was it , having the same problem with my 06 SS.
