SS emblem in grille of 7th gen SS
Old Oct 15, 2013 | 12:48 AM
SuperSportSS's Avatar
Default SS emblem in grille of 7th gen SS
Has anybody taken out the bowtie in the grille and put in an SS emblem? I'm kind of interested in doing it and need some opinions, Thanks!!
Old Oct 23, 2013 | 01:00 PM
vette guy's Avatar
question I myself wanted to ask, I've seen the "SS" on the grills of some of your rides and I think it just looks ...right. How did you do that?
Old Oct 23, 2013 | 01:06 PM
Yes you can do it
Take some fishing line and slide it behind the bowtie and gently pull it from side to side and down, should slide through and pop off.
Then get a SS emblem and some 3m double sided tape and stick her on!
Old Oct 23, 2013 | 02:09 PM
The SS emblem is the same SS emblem that is on the door you can get them on e-bay
Took me 10 minutes to put mine on. You want to make sure that where the bow tie was is CLEAN. I cleaned with rubbing alcohol
Old Oct 23, 2013 | 02:28 PM
Hiroska's Avatar
Imma have to go pluck one off of anther car >.<;
Old Oct 23, 2013 | 09:06 PM
vette guy's Avatar
thanks tadcaster, also like the hood on your car
Old Oct 23, 2013 | 09:53 PM
xxtheshockerxx's Avatar
RED DEVIL
One of the first things I did. Use the fishing line method and there is a plastic tab you have to cutoff behind the bow tie... Clean it with alcohol really good and stick the ss. Looks much better
Old Oct 24, 2013 | 07:09 AM
Nor sure I understand. Do you mean you trimmed down the mount on the grill where the bow tie used to be (Sorta like the pedestal where the bow tie was mounted to?)
I had thought of that but was worried I'd mess up my grille
Old Oct 24, 2013 | 07:10 AM
Thanks, you can find them at WWW.MPD1.com
Old Oct 24, 2013 | 09:06 AM
RED DEVIL
Yeah that might be it. It's like a little notch in the grill so the factory workers can't put it on crooked haha
