SS emblem in grille of 7th gen SS
Yes you can do it
Take some fishing line and slide it behind the bowtie and gently pull it from side to side and down, should slide through and pop off.
Then get a SS emblem and some 3m double sided tape and stick her on!
The SS emblem is the same SS emblem that is on the door you can get them on e-bay
Took me 10 minutes to put mine on. You want to make sure that where the bow tie was is CLEAN. I cleaned with rubbing alcohol
One of the first things I did. Use the fishing line method and there is a plastic tab you have to cutoff behind the bow tie... Clean it with alcohol really good and stick the ss. Looks much better
Nor sure I understand. Do you mean you trimmed down the mount on the grill where the bow tie used to be (Sorta like the pedestal where the bow tie was mounted to?)
I had thought of that but was worried I'd mess up my grille
Yeah that might be it. It's like a little notch in the grill so the factory workers can't put it on crooked haha
