Speedometer has lost it's marbles...
Old Nov 19, 2007 | 08:05 PM
Jobu's Avatar
Default Speedometer has lost it's marbles...
I have a 2005 Monte Carlo LS, about 35k miles. The speedometer is off between 40 - 60 mph, I can't get it to reset to 0. Anyone have any ideas as to what I can do to fix this??? Please help...Thanks
Old Nov 19, 2007 | 08:35 PM
06LT3's Avatar
Default RE: Speedometer has lost it's marbles...
A lil clarification, Like its off 40- 60 mph? or its off between 40mph and 60mph? And it wont go back down to 0? even when the car is off?
Old Nov 19, 2007 | 09:57 PM
04 Intimidator's Avatar
When you first turn on the car and it starts between 40-60 it needs to be reset. The only way I have found to do this is turn the iginition from off to acc. Let the gauges reset. Turn it back off and back to acc. You will notice it goes down a bit - like 5 mph. Just keep doing this till it goes to zero.
I had this problem myself. It has recropped back up but with the oil pressure gauge. The correct fix is to replace the gauge cluster but I've done that once already under warantte and I'm not anxious to drop $400 down on a new cluster.
Old Nov 20, 2007 | 09:17 AM
Jobu's Avatar
The speed that it's off varies...even when I turn the car off it just stays where it was. Like this morning when I turned the car off, it still said I was doing about 180 mph...
Turning to the ACC did work for a while in making it reset, after about 10 tries. Now that doesn't even work...
Thanks for your help!!!!
Old Nov 20, 2007 | 10:51 AM
DeboDaddy's Avatar
Don't fix it yet! Take a picture of your dash when it say 180mph and show any of your friends with fast cars...
Old Nov 20, 2007 | 01:45 PM
kweef's Avatar
lol good idea...good way to screw with their heads
Old Nov 20, 2007 | 05:28 PM
Ok, then it is just a shot cluster and not an intermitant one. Need to get a new cluster if it is simply not working anymore.
Old Dec 11, 2007 | 07:58 PM
Chucks88SS's Avatar
Yep, for some reason 03-04 clusters suck...GM knows, even had a TSB about it, but no recall. If its under warranty get it fixed, if not look on E-bay, and hope for the best.
Old Dec 16, 2007 | 11:45 PM
I think the "thanks for your help!!" comment was a subtle way to call me a jerk or something. He just didn't understand the thing wasn't working as it was and I gave a possible fix that ended up breaking it. So it went from useless to more useless?
Old Dec 17, 2007 | 02:23 PM
kweef's Avatar
well i wouldnt worry about it too much...he seems to come to fix his problem and left, oh well
