Speed Limiter
Old Sep 19, 2010 | 07:59 PM
Ice7891's Avatar
Question Speed Limiter
ok so does any one know how i would go about removing the speed limiter in my 07 v6 3.5L Monte?
Old Sep 19, 2010 | 11:59 PM
labnjab's Avatar
Only way is to have your PCM reprogrammed, but the reason for the speed limiter is to keep the car from going above the speed rating of your tires, so if you planning on doing extended high speed runs make sure your tires are rated for it.
Old Sep 22, 2010 | 02:50 PM
Ice7891's Avatar
yea i know why it has a speed limiter... and i have H rated tires so im not worried about it ... how would i go about reprogramming it... is there some were i could take it?
Old Sep 23, 2010 | 09:11 PM
seawolf18's Avatar
Unless you want to spend around $700.00 for HP tuners, or EFI Live, you can send the computer in and have it programmed and sent back. I had wait4meperformance do a mail order tune on the camaro I used to have, after I did a cam swap on it. I had no problems with it, and the guy that runs it definitely knows his stuff when it comes to tuning.
Old Sep 23, 2010 | 10:47 PM
dowmace's Avatar
Is there a shop near you that does dyno tunes? Most shops that tune the 3.8 engines can do this for you at a reasonable price.
Old Sep 23, 2010 | 10:51 PM
looks like he has a 3.5 not a 3.8 I'm actually thinking of buying an HP tuner just for the heck of it! I don't have any major mods but it is something that I really want for my 3.9....
Old Sep 25, 2010 | 11:03 AM
dowmace's Avatar
Shows how good my reading skills are
My statement still holds true somewhat if you have a good dynotune shop around they can tune it for you.
Old Sep 26, 2010 | 09:11 PM
Ice7891's Avatar
sounds good i'll have to look into it
Old Sep 26, 2010 | 10:00 PM
monte07's Avatar
i had a dyno shop tune mine a little to free up some things. the shop was glad it is a flex car they have seen alot of the older gen cars from the late 89 to 99 cars that are running horrible on the 7-10% ethonal they were tuning them so they can run better on the new type of gas. i had them bump from 107 to 110 no faster due to it only having four gears. i dont want to push it i am looking for a after market as well waiting for the new design for the 5 speed auto gm is making for the impalla 3.5 as well as the ss. cant wait it is still on the testing stage it said it was going to be a 5 speed or six speed trans it wasent all to cleare acording to the gm rep when i got my monte out of service department. i heard him talk about the impallas coming out with them as well as a replacement for the monte's for a aftermarket upgrade. well i am not going to hold my breath. p.s. i am a bad typest and a bad speller
Old Sep 28, 2010 | 11:32 PM
KJRich's Avatar
This question always started a major flame war when I was a Cavalier owner on the Cavalier forums.
