Sounds like water under dash
I have a 2005 Monte Carlo SS. Over the last few months is when the sound of water under the dash has occured. Haven't noticed any wet areas on the carpet and no stale water smell. Some days are louder than others and does it more when turning or going over bumps but does it when going staright.Any ideas.
When mine made a similar noise it was a leaking heater core. Sometimes when you would rev the engine then stop you could hear water sloshing around. It went about a month before it started leaking out. If thats what it is It's a pain in the butt to change and if you can afford to have it done for you it would be worth the money. Also I had to order my heater core no one had one in stock.
My bf's 04 SS makes the same noise.. i just think its coolant passing through( usually happened around corners.. sound came from pass side.. by heater core, ^^^ he did end up needing heater core fixed eventually
Motorhead
Apr 25, 2018 08:08 AM
hillre48
Aug 15, 2010 08:50 PM
