Sound of water splashing around in drivers side
Old May 18, 2011 | 08:07 PM
l0gitech87's Avatar
Default Sound of water splashing around in drivers side
Hi everyone. I am hoping someone can help me with a water issue I have in my car. It rained pretty heavy today, and I had left my car outside all day today during work. As I got in to go home, I noticed splashing sounds of water coming from the drivers side. I can't really locate if its coming from the rear quarter panel area or my door. The floors arent wet and neither is my roof, but I do notice that whenever I open or close my drivers side window the interior panel shifts back a tad bit. Could the water be coming in through the window frame? Will this cause rust immediately if I don't solve this problem? The weather stripping seems okay. The only part where there is a slight tear (about 1/2 inch is at the top right corner of the window frame. Any help or advice would be gladly appreciated.
Old May 18, 2011 | 08:31 PM
There's a drain in your door, it's possibly clogged. Check it out.
Old May 19, 2011 | 09:47 PM
Justin Knight's Avatar
X2 that happens all the time in monte carlo's. I actually drilled mine bigger and then used the larger hole to spray rust proofing as well.
Old May 20, 2011 | 07:09 PM
l0gitech87's Avatar
Hey guys, Thanks for the feedback. I did infact check under the door (just above the rubber moulding of the edge of the door) but did not find any drain plugs. Would it be recommended if I were to drill a hole at the bottom middle, drain the water and use a plastic plug to plug it? When I rustproofed my car they drilled a hole on the side of the door panel, will removing this plug drain it out? I'm also noticing that there is a rust build up at the bottom lip of both doors. Is this caused by the water? Man, rust sucks...
Old May 23, 2011 | 06:21 AM
It's behind the rubber molding on each end of the door.
Old May 23, 2011 | 09:11 PM
l0gitech87's Avatar
Hey Chibi, I'm sorry for the late reply. I was busy all weekend. I cleaned the car inside/out on saturday and greased the lips of both door panels and to my surprise both drain holes were plugged up with old black grease (this is why I did not notice them) so I did my best to clean them out with a q-tip and the water just came pouring out of both doors. I don't know how long that water has been sitting there for but I hope that this isnt whats causing my doors to rust from underneath. Thanks again guys for your continued support and help.
Regards,
George
Old May 24, 2011 | 06:01 AM
Glad we could help!
I also had that black gunk covering the hole closer to the firewall. It gets pretty nasty, just keep an eye on it every now and then.
Old Jun 17, 2012 | 02:10 AM
myfirstcar's Avatar
Hey guys I'm having a similar problem except my water build up is on the driver side floorboard, we had a good solid week of rain and now for the past two days my floor has been soggy. I noticed my weather stripping is coming off on the roof could this be the problem?
2005 Monte Ls
Old Jun 17, 2012 | 02:27 AM
This could be your problem. LINK https://montecarloforum.com/forum/si...lem-fix-26663/
Also it may be a leaking heater core. Also welcome to the site.
Old Jun 17, 2012 | 10:14 PM
myfirstcar's Avatar
Thanks a lot! Ill check it out tomorrow morning
