SOS- AC not functioning properly!!! It’s summer!
Old Jul 25, 2021 | 11:15 AM
Wsnowden's Avatar
Default SOS- AC not functioning properly!!! It’s summer!
This problem is a mind blowing one. The car blows fairly cold air at idle. But when driving, it gets significantly warmer. The air never really cools off the cabin. Sometimes when Turing the car at a decent speed, the air will cool slightly, then go back to being warm.
AC compressor is working, no refrigerant leak.
2006 SS
Old Jul 26, 2021 | 07:44 AM
Have you had your system vacuum tested to make sure it is full correctly?
Could be a blend door issue, could be air in the system.
Old Jul 26, 2021 | 12:43 PM
How are the pressures?
I had a somewhat similar issue on my 08 impala. The system had to be opened to service a component (a tube got externally damaged and had to be replaced). It was overfilled a bit after reassembly and was just squeaking by functionally at idle, but would shut off the compressor when you got some heat / rpm in it (ie from driving) due to over pressure.
Old Aug 4, 2021 | 09:52 PM
MCrider02's Avatar
Default Check filter
Have u check cabin filter if it has one!
jjohnson0130
Mar 29, 2021 09:18 AM
EvanLauer
Jul 31, 2020 09:36 PM
shynativegrl
Apr 12, 2015 07:00 PM
Habbibie
Mar 16, 2012 06:51 PM
Snyderman
Oct 26, 2008 06:04 PM
