Shudder to trans slipin
Old Apr 25, 2009 | 11:25 AM
jetman4u's Avatar
Default Shudder to trans slipin
Hey guys new to the form. i had a shudder when tuening right or a lil when going staight.I " my cusin and i"changed the cv axel since then "only a night"it slips when turning left,checked tranz fluid it was low...is there a seal i can replace and how do u install it...thank you all for the help...i have a 2000 mc ss 3.8
Old Apr 26, 2009 | 07:23 PM
jetman4u's Avatar
I found out that the new cv axel was not going all the way up and letting it leak....so now i have the old 1 back in for now...we tried to get the new 1 to go for about 3 hrs...checked it every way we could againt the old 1 ..it matched just would not go!!
Old Apr 27, 2009 | 07:37 AM
Enzo354's Avatar
STILL SLOW
I seriously dont know what to say. Mabye you just have to muscle it in haha.
Old Apr 27, 2009 | 11:41 PM
Sliver's Avatar
I just did the passenger side on my MC a week ago. The splines on the new shaft should line up and go in with relative ease. If it is being held up, try to tap the shaft into the tranny with a rubber mallet. Tap it on the hub type part that is past the inner joint. If you can't get a mallet in there, use a block of wood to butt up against it and then tap it in. It really shouldn't take much force to pop that little washer on the end into place within the tranny. If your cousin is around have him hold the shaft in place so you know that everything is straight.
Good luck. I was having the same type of vibration you are having under the same situations AND I am still getting the vibrations. The shaft was bad on mine so replacing it was no big deal but that shudder sucks.
Old Apr 29, 2009 | 08:46 PM
jetman4u's Avatar
Like you Sliver i changed my right side ...it didnt help with the shakes..but it did need it...did u change your left side too??? Also did u try your stuts???Keep me informed and i'll do the same Thanks
Old May 17, 2009 | 12:02 PM
jetman4u's Avatar
Fixed mine today!!!!I ended up changing both cv axels..it was the drivers side that was causing the shake....smooth as silk now...WoooHooo
Sliver
Mar 15, 2015 08:07 AM
farmerjg
Apr 19, 2012 09:42 PM
silvermike19
Dec 15, 2011 05:54 PM
J_Bru_Ha_SS
Mar 23, 2011 03:36 PM
MrCheesefood
Dec 17, 2008 07:41 PM
