6th Gen ('00-'05): Shaking to death.
Old Mar 26, 2017 | 02:08 PM
Sean2331's Avatar
Default Shaking to death.
Hey all, I could use some help figuring out a shaking problem. My 2001 SS is currently shaking. Here are the symptoms. The steering wheel shakes and vibrates at all speeds except for when making 90° turns. The car really starts to shake at 40mph either rolling or accelerating and gets worse at higher speeds. The car pulls to the right and starting at 35 mph a "rumble strip on the tires" kinda sounds starts up and gets faster with the speed of the car.
I had the car realigned, I checked tire balance, replaced the bearings, inspected the rims and have no idea what else. The car also pulls to the right and braking has no effect on the shaking. Its just there. I tried swerving from side to side to see if the sound was worse or better but nothing noticeable. Any suggestions? Could it be a bad cv, and if so what side?
Thanks for any replies!
Old Mar 26, 2017 | 08:03 PM
Smile
I checked tire balance?? did you have them balanced or just checked? there might be a broken belt in the tire. Also if some one removed a wheel and over torqued a wheel when it was put back on, this will cause the vibration as well.
this one you need to be careful with but you can put the car up on Jack stands then start it up and put it in gear, you should be able to view the front end in motion now and see what is happening. But this is a risky thing if you are not careful. So if you do it be real careful
Old Mar 27, 2017 | 04:16 AM
Imp42017's Avatar
I am going to guess that there is a Issue with your Sub Frame or Tie Rod or Ball joints.
Old Mar 27, 2017 | 07:13 PM
Sean2331's Avatar
I ended up putting it on jack stands and having a friend put it in gear and i watched the tires as they spun. I learned a lesson from this. Never trust my local tire shop. That passenger front tire was really outta round and the fact i payed money to have it checked sucks since that was the problem the whole time. Well, at least I have new bearings on both sides. Thanks for your help guys and thanks Drivernumber3
Old Mar 28, 2017 | 08:30 AM
WBody's Avatar
Bummer to hear that Sean; there are certainly are shady vendors around and not just in the automotive world.
Good to hear is working again with no more violent shaking.
