Seat covers for 98 monte carlo
Old Jul 3, 2011 | 12:41 PM
Jerry Rauch's Avatar
Default Seat covers for 98 monte carlo
What is available to replaceworn seat covers for a 98 monte carlo?
Was told by an interior guy that the factory glued the covers to the foam cushions, that nothing could be done. I can't believe this...
Old Jul 3, 2011 | 05:21 PM
welcome to the forum, please read this thread for more details on replacement covers!
New seat covers
Old Jul 3, 2011 | 06:14 PM
mrl390's Avatar
I believe he is looking for replacement upholstery am I correct? Never had the upholstery off my seats but they usually arent glued on. You should be able to peel the old upholstery off if you can find new upholstery to replace it with.
Old Jul 3, 2011 | 10:25 PM
Usually there just held on with some type of clip. A replacement stock seatcover should be available from a dealer.
Old Jul 8, 2011 | 11:32 AM
JaxJim's Avatar
I bought a set of front seat covers from "Precision Fit". They go over the original seats.
https://montecarloforum.com/forum/in...-99-z34-28375/
Old Jul 20, 2011 | 02:53 PM
jimmyfloyd's Avatar
I removed the seat covers on my old 98 LTZ to install heated seats a long time ago. They are not glued to the cushion, but do use velcro and some hog rings. It is best to get a hog ring plier set to re-install them, but I believe you could used some small zip ties if the original hole in the fabrick is fine, you just wouldn't zip it tight.
The bottoms I believe you unscrew the plastics on the side, and then there is a plastic C channel that slips over a rod on all sides. Undo that, look for and other rings or clips, then remove slowly, removing the velcro as you go. Reverse to install.
The back you start at the bottom. The is a long clip that folds in on itself that you remove. Then you start sliding it up the seat. The seahrest should be removed first, along with the trim for it.
What seats do you have now and what color/material are you looking for?
Mankowski3
Nov 4, 2013 05:11 PM
Cwitche1
Nov 8, 2009 03:53 PM
06 Monte NJ
Apr 14, 2009 12:15 PM
mikeymontecarlo
May 1, 2008 02:41 PM
zipsayain
Jul 17, 2006 09:19 AM
