Screeching noise from passenger foot well above 3500 RPM
Old Sep 23, 2011 | 07:30 AM
saigashooter's Avatar
Default Screeching noise from passenger foot well above 3500 RPM
So here is a new one, my passenger foot well is screeching at me.
When I hit about 3500 RPM a screech develops and contnues until I drop back below 35000 rpm
Does it with AC on or off.
Does it at any or no fan speed .
Does it in drive and nuetral.
My thoughts are the AC compressor is having issues, or that the serpentine belt is slipping at that speed range and the sound is coming through the foot well.
Any other thoughts or tests?
Old Sep 23, 2011 | 07:43 AM
03SSLE's Avatar
I would suspect the serpentine belt. Take a look at it and see if the grooves are worn or glazed. If they are you need to replace it. While you have the belt off clean your pullies so you don't transfer dirt/glaze from them onto your new belt. Also check the belt tensioner for proper operation. A worn bearing in a belt tensioner will squeel also.
Old Sep 23, 2011 | 08:10 AM
Just because you'll have the belt off, check the PS fluid too.
Old Sep 23, 2011 | 09:08 AM
Ha Ha, I do that every six months, it never leaks out anywhere but seems to get low at random.
chevykid404
Apr 5, 2015 10:08 AM
kudzmakid
Jun 12, 2014 06:54 PM
GqAmbitions
Mar 31, 2012 06:29 AM
cmanningjr
Mar 3, 2009 09:44 AM
