6th Gen ('00-'05): Rough idle
Old Feb 3, 2016 | 09:55 PM
Coatesy_24's Avatar
Default Rough idle
I have noticed recently when I'm coming to a stop light and have to sit there for a few minutes my monte idles kinda rough, it's "jumpy" and seems like I will stall any moment. I have looked around and saw a few suggestions. I would like to know where to start looking first?
I saw a post stating that a bad catalytic converter could cause this problem? In the past few days I feel as my car has gotten louder, could this be my problem? The previous owner replaced the mufflers and part of the exhaust but I am not sure if the converter was replaced as well.
Thanks in advance for any advice!
Old Feb 10, 2016 | 12:58 AM
xpage's Avatar
Might also be a dirty throttle body impeding airflow at idle. It isn't much work to get to it. 3 bolt for the throttle body and removing the intake tubing to it. Costs one brillow pad some shop towels, a new gasket, and a can or two of spray acetone (break cleaner or throttle body cleaner) so about $20 or less and 30 minutes of your time.
Worth trying before you go to the cat
