Reving up
Old Aug 28, 2011 | 06:14 PM
773 Z34's Avatar
Default Reving up
I have a 97 Z34 and sometimes upon start up the engine revs up by it's self. I'm thinking it's the fuel pump all advice will be appreciated
Old Aug 28, 2011 | 07:01 PM
mrl390's Avatar
Does it do it all the time or intermittantly? Could be a number of things. Vacuum leak or bad/dirty IAC valve would be the first thing I would look for. Try cleaning the IAC valve for a start.
Old Aug 28, 2011 | 07:21 PM
773 Z34's Avatar
It does it intermittently thanks for your advice bro will try that and
keep you posted
Old Aug 28, 2011 | 08:10 PM
zipper's Avatar
That doesn't sound like a fuel pump issue to me. mrl390 has good advice.
Old Aug 28, 2011 | 10:17 PM
773 Z34's Avatar
thanks for your. input zipper
Old Sep 7, 2011 | 05:55 PM
773 Z34's Avatar
My service engine light came on got it checked and it came up as purge flow slinoid do you think that could.be the cause of the reving up it also said that the throttle is out of place
Old Sep 7, 2011 | 05:57 PM
Might be wouldnt hurt to get those things checked out
Old Sep 7, 2011 | 08:35 PM
773 Z34's Avatar
Yeah this friday I'm getting a new purge flow and getting the throttle thing checked
Old Sep 28, 2011 | 05:26 PM
773 Z34's Avatar
Got a new tps sensor still getting the revving problem every time at start up now and there is small amounts of fuel being sent to the throttle body I thought just vapor/fumes go to the throttle body do you guys think it could be due to the purge flow being bad and mr l 390 I forgot your suggestion at the time but will make note to do so and one more thing some times she struggles to start up
Old Sep 28, 2011 | 09:13 PM
You have another thread that you identified a faulty head gasket. Not sure if that is playing into your revving problem or not. But my train of thought is, take care of the head gasket that you know is bad. If you are close to needing new plugs/wires, do those while in the neighbor hood. During the process of changing the head gasket you can see inspect things like vacuum lines and such.
