Replacing o2 sensor?
Old May 31, 2010 | 10:59 PM
Twitchy's Avatar
Default Replacing o2 sensor?
I am having issues replacing/finding the bank 1 o2 sensor. Common sense tells me its before the cc...but I can't see it any idea would be great. It is a 2002 monte carlo i believe the 3.8 motor. Any help would be great. Thanks
Old Jun 1, 2010 | 01:47 PM
Pretty sure if its the 3800, its at the end of the rear exhaust manifold right before the flange.
Old Jun 1, 2010 | 02:44 PM
Old Jun 1, 2010 | 07:46 PM
tridski's Avatar
I just replaced mine. You have two, one is between the firewall and engine. Remove the bolts in front dogbones and rock engine forward. The other one is underneath middle maybe a tad toward the front. Its on top on the exhaust between the floor and exhaust. Not hard at all. Hope this helps.
Old Jun 4, 2010 | 08:38 PM
tazman03's Avatar
i recently pulled the cat off a 2000 SS and the upstream O2 was right there on manifold as pictured above. Let me tell you this though..... it was a ****** #$%^&* to get the O2 sensor out of the exhaust pipe while I had it totally off the car and Very easy access. I could only imagine trying to do it behind the motor........ BTW I ruined the threads taking old one out. hac to buy a new one to put in the new cat pipe.
Old Jun 4, 2010 | 09:18 PM
RocknSS04's Avatar
An O2 sensor socket is a GREAT thing. It's a little extra deep, and is open on one side for the wiring. Expensive, but I can't imagine taking the top sensor out without it.
Old Jun 4, 2010 | 11:54 PM
Sliver's Avatar
I second the O2 sensor socket, I have no regrets about owning mine. And it's not like I change O2 sensors everyday.
Old Jun 5, 2010 | 04:52 PM
tridski's Avatar
Yes, get a oxygen sensor socket. Makes the top new a piece of cake. On the bottom one I just used a 4-way angled wrench and had no trouble at all. Always the right tool for the job makes it easier.
Old Mar 18, 2017 | 11:00 PM
Sosa Chamberlain's Avatar
Ok can someone help me. I have a 3.8 monte carlo with 270xxx miles on it and my check engine light is on. so i when to auto zone and had it scanned. I get 2 PO134 codes a PO131 and a PO141. I changed the rear 02 senor just about a year ago and the front 1 about a month ago can someone help me I don't know Wats going on.I ordered both parts off of ebay😧 but the rear one has held up until now
Henderson21
Nov 5, 2016 11:06 PM
phathead_rx
Feb 3, 2012 07:57 AM
The Rev
Oct 19, 2008 09:08 PM
rcohen
Feb 12, 2007 08:49 PM
sporges
Mar 25, 2005 12:29 AM
