5th Gen ('95-'99): Removing lower heater hose at firewall...any tricks?
Old Jun 21, 2019 | 03:47 PM
Shoddy's Avatar
Default Removing lower heater hose at firewall...any tricks?
I'm trying to change a blown lower heater hose on my 98...outs the lower one at the firewall. Is there a trick, tool or do i need tiny hands?
Old Jun 21, 2019 | 06:22 PM
Jeffs02rwdSS's Avatar
Easiest way is to pull the upper motor mounts and tip (rock) the motor forward and that should give you a lot more room to get to hoses . You also might need a spring clamp pliers to remove the clamp but otherwise pretty straight forward. Good luck
sishasmonte
Jun 21, 2019 03:40 PM
brendan127
May 12, 2012 10:39 PM
Franks 03SS
Sep 5, 2011 12:41 PM
shynativegrl
May 23, 2011 09:33 PM
pongogo3
Feb 20, 2010 10:29 PM
