Removing guage/radio bezel 07 SS
Old Jan 9, 2012 | 11:47 AM
Default Removing guage/radio bezel 07 SS
I have searched all over on the net today for this. I need to remove the carbon fiber imitation from dash and the radio bezel for painting. Is this stuff just snapped in? I hope so. What about door switch bezels? Snapped???? Thanks
Old Jan 9, 2012 | 12:48 PM
Jester_20's Avatar
radio bezel is just clips and it's pretty easy to get off (6 clips--3 on each side top, middle, bottom, and none going across the top or bottom), however i couldn't tell you for the carbon fiber stuff (never had it off). I usually take my whole interior door trim out when messing with the window switches and door locks, just because it's easier. If i remember right they're just clipped in, but it's pretty much impossible to unclip them if the door panel's still on.
good luck!
Old Jan 9, 2012 | 12:50 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
Be careful when you paint them. When I did mine, the carbon imitation started bubbling and I had to start over, after sanding them all the way down to plastic.
Old Jan 9, 2012 | 01:12 PM
Does all the vents and stuff stay attached. Someone is doing this project for me once I get it all removed and I don't want them stuck in a big mess for something they didn't sign on for. Originally I thought they would all just snap out. How does the guage bezel come out? Do you haev any pics of yours finished?
Old Jan 9, 2012 | 04:31 PM
I did manage to get the radio bezel out.
Old Jan 9, 2012 | 04:48 PM
Jester_20's Avatar
any luck with the gauge cluster?
Old Jan 9, 2012 | 05:08 PM
I am not even gonna mess with that right now. Maybe later. I am just gonna get the radio bezel and both door lock switch surrounds done for now. I had the area off the door, but couldn't figure out how to get the actual switch out of it. I see it will unplug, but I want the switch completely out. It appears to have prongs on the sides of switch but I couldn't get it out. Maybe it goes out the front and not the back. Any suggestions? I think doing those 3 pieces for now will add some color to inside. Edit:I think I have the door locks figured out. Found something on Barovelli.com showing me how finally. I was doing it right, just not getting it. Another day tomorrow.
Old Jan 10, 2012 | 01:07 AM
Barovelli's Avatar
See this thread about door panels and lock switches - has my website post and some awesome MS Paint diagrams from another member --> https://montecarloforum.com/forum/se...l-20761/page2/
Old Jan 10, 2012 | 06:36 AM
Thanks Barovelli. That is the same article on found on your site. lucily I kept going through the pages on google. It was on the third page, I usually give up after 2. Gonna give it another try this afternoon. Great info.
Old Jan 10, 2012 | 10:47 AM
Sorry it took me so long to respond. The gauge cluster does not snap out. It it plastic welded to the rest of the piece. I drilled out the plastic welds and replaced them with small bolts that I haven't completely refinished yet in order to paint properly. The vents do come out. There is a combination of screws and clips that hold them in place.
