Door panel removal
Old Jun 10, 2010 | 02:42 PM
Sciggy's Avatar
Couldn't get the panel off. I wasn't clear on how to remove the power window switch from the bezel. Looking at it, it doesn't seem clear. Any tips/advice on that?
Old Jun 10, 2010 | 03:08 PM
lucian*91's Avatar
on the reverse side if the switch, there should be a clip to push out and it will slide free. you can usually stick a small screwdriver inbettween the switch and the clip and the switch slides out
Old Jun 10, 2010 | 03:22 PM
lucian*91's Avatar
if this helps.
AND DONT MAKE FUN OF MY HORRIBLE DRAWING!!!..LOL
Old Jun 10, 2010 | 07:53 PM
Sciggy's Avatar
So I need to take the panel off before I take the switch out? The directions say to take the switch out before you take the panel off.
Old Jun 12, 2010 | 10:02 AM
lucian*91's Avatar
i usually leave those switches in and take them out after. but i didnt notice you have a 7th gen, its a little different.
Old Jun 14, 2010 | 10:37 PM
Sciggy's Avatar
Thursday I'll have time again to take a look at it. Gonna try and progress without taking the switch out and see where that gets me. I'll update where I can
Old Jun 14, 2010 | 10:49 PM
mak330's Avatar
i usually only take out the one plug, that give your plenty of room to do what is needed in there. just rotate the panel and vway la. at the shop i watched them take out all the switches[buttons and all] , then i took it back the next day cause none of my buttons worked. lol nothing was broke just out of place.
oh ya put a shirt or blanket under the corner not to scratch the plastic.
Old Jun 26, 2010 | 12:58 AM
Cyst3m's Avatar
=D uh-oh, now that i know i may have to do some interior painting! thanks for the how-to!
Old Jul 3, 2010 | 05:26 PM
Barovelli's Avatar
1, 2 & 3 are phillips. #3 failed to alert me of its presence and I had a bugger of a time before I just laid down on the ground to look up into the loose panel and saw it.
4 & 5 are T30 Torx
The door handle & lock switch panel. Easily pry from front. There's tabs in the back.
Tabs
The latch for the power lock button is on the hidden side of the socket, FYI. I pried the switch off of the panel, it slides out from the back.
Lock switch
Sneaky screw #3
The Torx kit. I love Wiha tools
This one was more difficult, the spring steel tabs were snapped in a fashion that prying would not release it. That and I totally missed screw #3 which would keep the panel from ever coming off. Note that the brushed metal trim does not snap off, though it gives the appearance that it does.
I let it lay and worked it from the inside of the panel while it was off of the door. There's enough slack in the wiring. Mak330 says to put something down to protect the bottom edges while working on it, good advice.
Looking down as if from the top of the window. The top edge of the panel hangs in several of these clips. After removing the 3 phillips screws, the 2 torx screws and the door handle trim I slowly unsnapped the panel from the lower left corner then continued along the bottom and up the sides. Swing it out a bit and pull up.
The bottom & sides are snapped in. Note that the long panel back of the door handle and the speaker grille are glued & melted on and do not snap off from the inside. Bummer, I wanted to clean the speaker grilles.
Here's why I am here - one nut on the mirror attachment was loose. Made the mirror shake and jitter. There's a sponge piece that adds insulation in the cavity over the mirror nuts. There's no glue on it.
In all respect, I could have just undid screws 1-5 and pop the panel off to reach the mirror nuts. But curiosity made me want to learn more. Thanks for the hints.
Old Jul 7, 2010 | 05:36 PM
Thirtybird's Avatar
Thanks for the pictures and advice! I've got a bum mirror switch and will probably look into it myself and knowing what you faced will help. If you don't mind though - is it possible to get the panel for the window and mirror switches out just by removing 3,4 and 5 and carefully prying? (I read that you couldn't but the mystery #3 screw might have been your culprit)
TIA!
