remote start problem
Old Dec 29, 2016 | 06:54 AM
tfunk002's Avatar
Default remote start problem
my remote start only works when i am next to the car
I have an 06 Monte Carlo LT i would like to be able to use the remote start and keyless entry from inside my house
could any one please help me
Old Dec 30, 2016 | 09:18 PM
jakefluker's Avatar
Wow, is this the factory remote start? If so take to dealer and ask them to adjust distance. if aftermarket take to anywhere reputable to adjust distance. Hope this helps out your situation.
Old Dec 31, 2016 | 07:15 AM
tfunk002's Avatar
no it is factory.
I also read on here that alot of 06 monte carlos have had the problem with having this problem with the distance of the remote start. There is a TSB on the web about this problem.
Old Dec 31, 2016 | 09:29 AM
Yeah GM did have some receiver issues on these cars, unfortunately it was never a full recall and it is a little pricey to get fixed.
You can talk to your local dealer about the TSB as that will let them know everything that they need to replace, but I believe it's the whole receiver, and new FOBs to get it working the usual 30-50ft again
Old Dec 31, 2016 | 08:54 PM
tfunk002's Avatar
i went for a safety recall on my car. I did mention that to a service writer.
I had the paper i printer offline about a GM tech having the same problem.
The service writer said it could be as simple as an update on the computer like the GM tech said.
If you can get the whole TSB I would like to read it.
I can not find it anywhere online
Old Dec 31, 2016 | 10:07 PM
tfunk002's Avatar
another question I have. If the gas cap message shows up on the dash with the check engine light after you check the gas cap does the computer remember that the gas cap is loose. I have tighten the gas cap when i got that message what else can be going on ?????
Old Jan 2, 2017 | 02:21 PM
96z34man's Avatar
You have a vacuum leak somewhere. Someone smarter than me will have to tell you how to track it down.
Old Jan 2, 2017 | 08:45 PM
tfunk002's Avatar
ok i will check it out
Old Jan 3, 2017 | 02:13 PM
It can also take 50 miles / 3 drive-cycles to reset.
Old Jan 3, 2017 | 08:32 PM
tfunk002's Avatar
i have driven more then 50 miles with 3 cycles the check gas cap is still coming on what else is there that i can do
