Relearn After Overkill PCM Install?
Old Jul 10, 2012 | 08:40 PM
03SSLE's Avatar
Default Relearn After Overkill PCM Install?
I was looking at PCM tunes for my Monte from Overkill and saw this notice:
'You may be required to have a CASE or Crank Position Sensor Relearn performed to match the new computer module to your engine.'
So, has anyone that purchased a PCM from them actually had to have a relearn done or did you just plug in the new PCM and go for it?
Old Jul 10, 2012 | 08:43 PM
It's very common with Monte Carlo's to have to go through the security relearn process, I had to when I got my ZZP PCM.
Old Jul 10, 2012 | 08:59 PM
mairj40's Avatar
I have an Overkill PCM. When I installed it, I just had to do the security relearn procedure. The instructions were included with the new PCM. Pretty simple. I did not have to do anything with the CASE or crankcase position sensor.
Old Jul 10, 2012 | 09:02 PM
03SSLE's Avatar
Thanks Amy. Is the security relearn you refer to the 11 minute ON 30 second OFF X3 process or something different? If so I can do that myself. It's the crank relearn I was most curious about. Did you have to have that done in addition to the security relearn?
Old Jul 10, 2012 | 09:04 PM
03SSLE's Avatar
Cool...thanks!
Old Jul 10, 2012 | 09:06 PM
If I can figure it out anyone can
Old Jul 10, 2012 | 09:10 PM
03SSLE's Avatar
Thanks again Amy...
So then I assume you didn't have to do a CASE or crank relearn then?
Old Jul 10, 2012 | 09:14 PM
Thank goodness no LOL!!!! Just the security relearn
Old Jul 10, 2012 | 11:26 PM
Crusader SS's Avatar
Hey Frank... I got my tune in car from Will and when we were done I took it easy and went straight to the dealership to get the "Re-learn" done... When I got there the technician looked puzzled, as to get the re-learn done, your car will definately throw a code... No code after the install, no need for the re-learn... Needless to say that 2 years later and more WOT trials than I can count, all is well... Hope this helps,
PS - The code that the CEL will throw is listed on the instructions from Will, sorry, but I don't have it handy...
Old Jul 10, 2012 | 11:28 PM
If you have to take it to the dealer for the re-learn what do they usually charge for this?
