Rear brake seized, 1996 Monte Carlo
Old Feb 9, 2021 | 09:10 AM
DudeWithThe96's Avatar
Default Rear brake seized, 1996 Monte Carlo
Hey fellas. I've got a '96 with a rear brake that won't release. I've loosened all the lines and went to town on it with a 12lb sledge but it still holds strong. I can't seem to get the adjuster to work. Looking at the other brake it seems that the teeth are made to turn the adjuster out and tighten the brakes but slip in the other direction. Any help to keep me from cutting the damn thing off will be appreciated graciously.
Old Feb 11, 2021 | 06:29 AM
Anyone out there with experience on this matter?
Old Feb 11, 2021 | 01:20 PM
nitehawkjcb's Avatar
So you're not able to get the drum off? You can try setting and unsetting the parking brake, and you could use some PB blaster.
Old Feb 11, 2021 | 07:03 PM
I finally got it just this morning. For anyone who might have this issue, spray the thing with PB blaster, remove the torx bolts (wtf are those, GM?) holding the brake cylinder on, I used a 1/4 wrench. Then literally beat the brakes off of it with a sledge while using the wedge on the tire iron to help pry it off. However that bent the dust cover up.
Old Oct 27, 2021 | 09:37 AM
Did you get this all back together?
What was the main issue?
I had a fellow up the street who had a similar problem and the brakes has wore down the drum and wouldn't release.
cdesjardins1988
Aug 21, 2017 10:33 AM
iMSeRiOuS
Mar 19, 2013 06:38 PM
iMuf
Mar 12, 2013 11:26 AM
rickhev1
May 17, 2012 05:30 PM
zapp59
Jan 25, 2009 12:38 AM
