5th Gen ('95-'99): Rear brake removal
Old Aug 4, 2019 | 06:55 AM
Robert Campbell's Avatar
Default Rear brake removal
I am tryin to change the rear brakes on my 1998 monte but cant seem to find the bolts to remove. Not sure if I just remove to two 15 mm bolt altogether.
Old Aug 4, 2019 | 07:15 AM
Check this link and find the one you want scroll to the lower part of the page, there are Luminas and Montes on here. all pretty much the same.
https://www.google.com/search?client...98+monte+carlo
Old Aug 4, 2019 | 11:56 AM
the setup of the brakes and caliper doesnt have the same bolts or set up as the videos in the link.
Old Aug 5, 2019 | 08:20 AM
Smile
So while you are at the Youtube site just enter in the search what you are looking to do and hit enter and you should get several options. or you can get a manual on Monte Carlo repairs too.
You didn't say weather the Car had disc brakes in the rear or drum brakes? Once you put that in the search they will show up. There are a bunch of videos on both in there that will direct you thru the entire process. Good luck.
rdorris84
May 18, 2013 11:09 AM
Bitchnbobb
Jan 25, 2012 05:57 AM
Bitchnbobb
Jan 26, 2011 10:22 AM
MarkIV396
Dec 11, 2009 07:58 AM
mdowie
Jun 8, 2006 05:21 PM
