Rear Brake Conversion for a 2003 Monte?
Old Jan 21, 2012 | 06:47 PM
BUDDZZ's Avatar
Default Rear Brake Conversion for a 2003 Monte?
Hey I've got a full set of 2002 Corvette Z06 brakes, I know the front will work and I'm in the process of getting those mounted up. I've been told that the rear brakes will not work. I'm wondering if anybody knows of any other rear brake conversion I could do, or other members have done. Any help would be great thanks
Old Jan 21, 2012 | 07:05 PM
Grand Prix GXP or ZZPs upgrade kit is all ikn of
Old Jan 21, 2012 | 07:15 PM
BUDDZZ's Avatar
I've heard of the GXP's and I've looked at ZZP's, how big of a job is the GXP's or is it a direct bolt on?
Old Jan 21, 2012 | 07:24 PM
Ive nvr done it yet but im going to but i imagine its direct bolt in sence both cars are w bodys so most of the parts are the same
Old Jan 21, 2012 | 07:28 PM
Justin Knight's Avatar
How are getting Z06 rotors to fit on a 5x115 hub?
Old Jan 22, 2012 | 10:10 AM
BUDDZZ's Avatar
Don't need the rotors use the stock monte rotors just grind down pads at a machine shop
Old Jan 22, 2012 | 10:15 AM
Why do you need to grind down the pads? im running Camaro calipers which are the same & i nvr ground down any pads
Old Jan 22, 2012 | 10:30 AM
Mr.Monte's Avatar
Old Jan 22, 2012 | 02:53 PM
BUDDZZ's Avatar
I was told I would have to but I'm going to fit them first and if they fit then I wont grind them down.
Old Jan 22, 2012 | 03:05 PM
Never heard of doin that, ikn with the Vette calipers you gotta shave the ribs down on the top of the caliper to clear 16s but thats all the modding ive heard of
