rattle vibration from rear dash?
02 SS with 243,000mi
Sometimes when I hit a bump, road seam or gravel road I get a terrible rattle like the rear window is about to pop out. It almost seems like the body welds are broken. The rear dash seems a bit worn and may be loose. I think I will try removing it. I already reset the spare tire and unclipped the amplifier. Anyone else with this type of problem? Thanks in advance. |
Rear strut could be worn, or loose.
Really struts do that? thanks I'll check that next. I was more worried the rear window rusted out. The car age and high mileage I didn't expect the strut to come loose. We have put the last 43,000 on it. I expect all the struts are at leaste a little flat.
