radio draw
Old Apr 23, 2015 | 06:52 AM
avendo's Avatar
Default radio draw
I have a 2.20 draw on my car,when I pulled the radio fuse it goes to .061..i did change my radio a while ago,but the car sat for a month + in my tent for the winter and never had a problem starting..this week 2 times the car would not start..only when I went to my Girlfriends house..mon and thurs morn it didn't start..what can I do about the radio drawing..doesn't make sense...
Old Apr 23, 2015 | 09:53 AM
avendo's Avatar
I unplugged the amp in the back and it went to 1.71..
Old Apr 23, 2015 | 07:55 PM
avendo's Avatar
saw my friend that works at my cousins GM dealership and he says its a bad radio..
Old May 16, 2015 | 08:26 PM
avendo's Avatar
Well I put another radio in the car and I get the same draw 2.2 Amps.. My original radio does the same thing what else could it be... If I pulled the amp plug out it drops to 1.75 amps
Old May 17, 2015 | 09:47 AM
Since it all started at your girlfriends.. I'd stay away from her.
Just kidding of course.
I would start with checking all your body grounds..
it sounds like the system could be back feeding looking for a ground. Thus killing the battery.
If you did this installed yourself.. I would take it to an audio shop and get it fixed..
Old May 18, 2015 | 06:52 AM
avendo's Avatar
its a factory radio..I have 3 of them and they are all reading the same,so where would the grounds I have to check be?
kkritislas
Aug 30, 2014 05:33 PM
ladybridgeport
Mar 22, 2012 01:05 AM
ladybridgeport
Apr 28, 2011 08:23 PM
craig229
Mar 6, 2010 12:49 AM
Yellow_Monte
Jul 19, 2007 05:54 PM
