A quick question!!!
Old Apr 14, 2012 | 02:14 PM
GqAmbitions's Avatar
Default A quick question!!!
What all do i need to do a coolant flush far as equipment??
Old Apr 14, 2012 | 02:27 PM
Ricks 2006 SS's Avatar
I was going to be a wise guy and just say a hose. But thats really about all you do need. You can buy some radiator flush from Walmart or any auto parts store. All I do is take off the bottom hose and let it drain out. Stick to hose to fill it while its draining out. Then after it turns nice and clear. Make sure its filled then start the car let in get to operating temp heater on full. Then shut it off till it cools. Take the bottom hose off again. Then just run water thru it. Till you think it looks clear enough. Then fill it with 50/50 coolant & water. Sounds harder then it is. Should take about 30 mins or so. Good luck
Old Apr 14, 2012 | 04:26 PM
aussiek2000's Avatar
+1 to what rick said. Other than make the mixture stronger than 50/50. The block and heater core will still be full of straight water.
ckd
Jun 14, 2006 05:22 AM
TKay2000monte
Nov 13, 2005 12:46 AM
OC_Broo
Aug 22, 2005 02:54 AM
myride05
Feb 24, 2005 06:44 PM
pg2676
Feb 19, 2005 02:12 PM
