quick question
Old Jun 15, 2010 | 06:01 PM
02montecarlo's Avatar
Default quick question
Hi I have an 02 ss and am planning on replacing my evap purge solenoid. Now do I have to releave the pressure on the fuel lines by taking the gas cap off then take off the solenoid or does it matter?
Old Jun 16, 2010 | 10:40 AM
There's a schrader valve that you can use to relieve the pressure
Old Jun 16, 2010 | 10:58 AM
kweef's Avatar
are you removing your fuel lines to replace the solenoid? if so then yes otherwise idk y you would need to relieve fuel line pressure
ckd
Jun 14, 2006 05:22 AM
TKay2000monte
Nov 13, 2005 12:46 AM
OC_Broo
Aug 22, 2005 02:54 AM
myride05
Feb 24, 2005 06:44 PM
pg2676
Feb 19, 2005 02:12 PM
