question
Today while coming home, i was on the highway in overdrive around 70mph. and i floored it to go around someone, and the car acted like the tranny was slipping, the the check engine light blinked about 18 times. i checked the trans fluid and it seems to be full. what could this be? thanks
A blinking Engine light is not good at all. Hard to say what it is from what you are telling but your best bet is to get the code read either at a shop or taking it to an auto part store that will let you use their reader. The blinking check engine light is worse than a solid one. Usually they say if you see a blinking check engine light to pull over as soon as you can or get it to a gas station with a shop. Even if the light is not on anymore it should have stored in the computer and you should still be able to read it.
yea tomorrow im going to get the code pulled so i know what it is. but does anyone know what kind of warrenty our exhaust has on it.
well i called the chevy dealer this morning and told them everything that it was doing, and they said it sounds like the cat is plugged. im hoping that is what it is because they said for the 03's its 8yr/100,000 wry on that. the car kinda seems to bog more and more the way it feels. and the code was a engine misfire, and i also told that to the chevy dealer and they told me that a plugged cat will make that code come up. lets keep the fingers crossed.
well i went to the chevy dealer after work, and they didn't even need to test the exhaust they could tell that the cat was really plugged just driving it into the building. they threw a new cat on it. and all I can say is WOW the amount of power it has now, i cant remember the last time i felt that out of the car.
