Popping sound
Old Oct 13, 2007 | 04:59 PM
thewhitestcarlouknow's Avatar
Default Popping sound
When i am first starting out mainly in reverse and at low speeds, there is a popping sound. Also if i punch it the sound is heard. Has anyone had this before or know what i am talking about?? Any ideas?? I am around 50000 miles and need to change my transaxle fluid, does anyone know if that could be the problem. Any help would be awesome. Thanks.
Old Oct 13, 2007 | 10:23 PM
FlynhghR's Avatar
Default RE: Popping sound
Could be a bad bushing... engine mount, or something in the suspension.. Does it seem to come from a certain side? can you feel it in the steering wheel at all?
Old Oct 14, 2007 | 12:45 AM
2000LS's Avatar
ORIGINAL: FlynhghR
i was thinkin steering shaft too
Old Oct 14, 2007 | 05:55 PM
When turning it also makes the noise but i cannot feel it in the steering column. It is usually only when i make sharp turns.
Old Oct 14, 2007 | 06:25 PM
Mrrench's Avatar
Check your drive axles (cv joints)
Old Oct 15, 2007 | 11:50 AM
MXMagnum's Avatar
Could be your steering rack. Just had mine replaced - only 6000 miles. Noticed at low speeds during sharp turns like when backing out of garage, parking space, etc. New rack and no more noise.
Old Oct 15, 2007 | 01:59 PM
06MonteSS's Avatar
ORIGINAL: MXMagnum
x2...
got just about 40,000 miles on mine... have a new steering rack on order, since replacing the ISS didn't do anything for it...
Old Oct 15, 2007 | 10:27 PM
thanks. About how much did it run you to have that replaced???
Old Oct 15, 2007 | 10:47 PM
FlynhghR's Avatar
My ISS just got lubed for free, not only did that improve steering feel by a TON, it also cleared up a slight knocking in the steering wheel when turning at low speeds, like in a parking lot, etc. I was thoroughly impressed by the improvement.
I'd look that up, a job most weekend-tinkerers can get away with doing themselves without causeing serious damage.
Old Oct 16, 2007 | 06:49 AM
06MonteSS's Avatar
ORIGINAL: thewhitestcarlouknow
nothing... it was under warranty..
