po102
Old Apr 22, 2010 | 01:41 PM
dupree155's Avatar
Default po102
i have a 2002 ss 3.8 and my check engine light is on and sometimes it goes off for a drive cycle or two then cmes back on i had the codes read at autozone i they said it was po102 which has something to do with the air system either the maf sensor or vacuum tube hose etc.. well i took the maf sensor off and cleaned it and put it back on but nothing happened would appreciate any help thanks
Old Apr 22, 2010 | 01:54 PM
If cleaning the MAF didn't cure it, and you still get the P0102, you may have to replace the MAF fully.
Do you have a reusable filter on your car that is oiled? Sometimes oiled air filters can ruin a MAF.
The connections for the MAF may be poor also, double check your wiring to make sure it's not broken anywhere.
Old Apr 23, 2010 | 03:31 AM
dupree155's Avatar
O ok thanks ill try that..... but no oiled filtter just a regular filter..ok and ill check the wiring while I'm at it....ok a question ? My low collant level light is on and I wanna flush my dexcool out to see if that would help I opened the radiator cap and its sludge on it but I can't seem to get to neither the drain plug or the lowere radiator hose???? Wat should I do?
Old Apr 23, 2010 | 09:18 AM
You'll definitely need to get that coolant flushed and hope it hasn't done any damage. Dex-cool goes to crap if it's mixed with the green stuff, so I hope it's just old and nothing was mixed.
If you can't access the drain points you should take it to a job and really get it flushed. You are right about the sensor just probably being gummed up.
Old Apr 23, 2010 | 07:47 PM
dupree155's Avatar
Ok thanks ill do it but I can't seem to get to the radiator hose I can see it but I can't take it off do I have to remove anything to get to it?
Old Apr 23, 2010 | 09:08 PM
Steven73's Avatar
On my 2005 SS thier should be a plastic drain **** bottem left (driver side) on the rad. i think it was like a 5/8 socket not sure... tight spot I thought. It was easier to get it from ontop engine then it was from underneath the car. Make sure you Bleed the bleeder ontop thermostate.
Old Apr 28, 2010 | 08:39 PM
dupree155's Avatar
Ok I flushed out the dex cool and the low coolant light is still on...so I'm thinkinits the sensor I located the sensor just don't know how to remove any help?
98monty
Jun 15, 2011 01:13 PM
