PLEASE HELP!!! 2003 SS - A/C Low Pressure PSI
Old Nov 16, 2011 | 07:24 PM
jcoeracing97's Avatar
Exclamation PLEASE HELP!!! 2003 SS - A/C Low Pressure PSI
Ambient temperature is approximately 75 degrees:
What should the psi be on the low pressure side of the a/c as well as the total R134a and oil capacities? The a/c is blowing cold and it's holding at 35 psi after adding 1/2 can of R134a. The reason I ask is because it was blowing cool but not cold air on either outside or recycle switch settings.
Most general information I've found is based on psi at a given ambient temperature which is stating at 75 degrees the L/P side should be 35-45 psi. I'd feel more comfortable knowing what the General Motors recommendation is. If 35 psi is considered acceptable even if it's at the low end, I'll accept that answer.
Also, the a/c sytem has never needed servicing or the need for refrigerant since the car was bought new.
Personally speaking, it needing 1/2 can in eight years is pretty good!
z34phoenix
Oct 31, 2011 09:02 AM
scc24540
Nov 30, 2009 02:43 PM
magnnuss_75
Jan 14, 2009 11:20 PM
fxdrider
Oct 1, 2007 09:39 AM
06LT3
Jul 18, 2007 10:05 PM
