Permanent fix for moisture in tail lights?
OK, here is also a possible fix, might just try this myself!!
How To Remove & Stop Headlight or Tail Light Water Condensation - Pictures Illustrated Automotive Repair Guide
Mike
Mike
No problem, hope you get it figured out! It is raining herre in PA, (again, ...or still?). just went out and checked and today the moisture isn't present. Seems to be during temp changes, let us know how you get on please!
Mike
Mike
Green house effect? Would not all cars get this then.... And most don't.. Not trying to be a devils advocate and such, but I think a sealed unit typically does not get moisture penetration. I'll look into this more. Could be up in the night on this.
After sealing mine they were fine for a couple of days...until the weather changed. Yesterday I took the tail lights off and dried them in the oven (30 minutes each @ 200 degrees), then drilled a 3/8" hole in the bottom of each. Too early to tell if that did the trick or not but I'll follow up in a few days and let you know if the moisture returns.
LOL!!! Nothing wrong with a difference of opinion, or a different way of approaching anything, debate is always good!! My thinking was the unique shape of the MC tail-lights, not too many cars have the rounded oblong shape that ours do, I think that contributes a lot to the problem?! That's the angle I was approaching my opinion from.
Mike
Repair Guide: Permanent Cabin Air Filter Water Problem Fix
ChibiBlackSheep
FWD Tech Guides '95-'07
113
Feb 17, 2025 01:55 PM
RickAKATed10
Jan 23, 2009 10:38 AM
