PCM Tray
Old Oct 27, 2006 | 05:13 PM
2000_BLACK_SS's Avatar
Default PCM Tray
Has anybody ever used the pcm tray from 3800performance.com and if you did how did it work did every thing fit or did you have to move some stuff around. becasue i was looking into buying one but i took a look at the wires and it doesn't seem that mine on the pcm would reach to where the pcm tray sits. thanks for any info
Old Oct 28, 2006 | 02:21 PM
FoxintheDen's Avatar
Default RE: PCM Tray
I ordered one once and got it to work but I had to move a lot around! In my opinion just order a cold air intake that has the PCM tray at the bottom of it.
Old Oct 30, 2006 | 07:08 AM
04 Intimidator's Avatar
The Wizaired Cold Air Intake from ZZPerfomance.com just uses straps built in to hold it down. Otherwise I've heard you can use the PCM tray from a 1996+ Chevy Blazer. Check out the local junkyards and the PCM Tray will be located on the passenger side of the engine bay at the top.
Mr.Monte
Sep 26, 2011 03:18 PM
Cowboy6622
Feb 2, 2008 08:59 AM
Cowboy6622
Jan 6, 2008 05:51 PM
monteriderLS
Aug 30, 2006 03:34 AM
GrandPaDave
Aug 14, 2006 09:00 PM
