Passenger Side Airbag???????????????
Old Oct 18, 2008 | 06:06 AM
06 Monte LT's Avatar
Default Passenger Side Airbag???????????????
I have a problem with the passenger side airbag light on my 06 Monte. I started it up, and recieved the normal blinking on the dash, but the on/off light wouldnt switch to either on or off. I thought it could have been some of the things on my passenger side seat putting weight on it confusing the seat sensor, but it wasnt. So i am having a hard time understanding this when I dont have passengers in my car.
So im confused. What could this be? Bad seat sensor? Maybe the air temp outside messed something up?
PLEASE HELP....Ive had this car for a month and this is the first problem
Old Oct 18, 2008 | 07:56 AM
RocknSS04's Avatar
Default RE: Passenger Side Airbag???????????????
The 1st thing I'd check is the connections under the seat. I believe the yellow connections are for the air bags. Maybe something got under the seat and pulled a connector? Anothe possibility is that the air bag control module is giving you problems. Hope for the 1st.
Old Oct 20, 2008 | 04:04 PM
I did check the connector out, and everything was fine under the seat.
I dont even want to think about option 2, so Im goin with option 3.
I think I had a balance of weight on the seat with my lunch and laptop for work that was fooling the system, or I had an extra passenger with me in the bright early hours of the AM
blownincome
Jul 12, 2013 02:05 PM
MJClemm
Feb 2, 2013 04:35 PM
Jokers1995
Jul 31, 2012 09:11 AM
BlackRainSS
Jun 25, 2012 10:58 AM
kanianic
Jan 1, 2011 07:03 PM
