P0420 Code Issue
Old Feb 20, 2013 | 06:11 PM
02CHEVYMONTESS's Avatar
mine is ontop of a u shape pipe so it doesnt hang down or anything. my space ontop is limited but i may have enough space..its 10 degrees with no garage here this week so i cannot check yet
Old Feb 20, 2013 | 09:41 PM
Originally Posted by 02CHEVYMONTESS
I found a site that i can buy a pcm with the code removed.
I know a guy who for a small fee could be willing to tune out that P0420. Shoot me a PM if interested.
Old Feb 21, 2013 | 04:36 AM
That would be great but I donot ahve another car to drive in the mean time.
Old Feb 21, 2013 | 02:09 PM
what would be a good tuner to buy to remove the code myself?
Old Feb 21, 2013 | 02:15 PM
Nothing cheap. A discontinued DHP Powrtuner or HPTuners are your options.
Old Feb 21, 2013 | 02:16 PM
i tried finding dhp with no luck
guess ill have to try that reducer trick if i have enough space for it and the o2 sensor. any one esle ever do it?
Old Feb 21, 2013 | 02:52 PM
03SSLE's Avatar
Although the P0420 code refers to cat converter efficiency, there are several things that can trigger the code. Do you have any leaks in your exhaust system? How do the wiring harnesses look going to both O2 sensors? Since you say your mileage appears normal we'll rule out a faulty injector as the cause for the code. If the exhaust system and wiring harnesses check out okay have your mechanic monitor and compare some real time data on both O2 sensors using a Tech II (or equivalent) scanner. Speaking of sensors, what brand did your mechanic use? A lot of aftermarket sensors don't replicate OE parameters and can cause problems right out of the box. If the readings from both sensors are too close to being the same it will trip the code, but it is the sensor that's faulty - not the cat converter. If the sensor used is anything but an AC Delco or Delphi that may be the whole problem.
Old Feb 21, 2013 | 05:21 PM
I have to check to see what sensor i used
Old Feb 21, 2013 | 06:38 PM
My rear o2 sensor is from the company
GLOBAL AUTOMOTIVE # SG277
