p0403& p0404
Old Jan 26, 2011 | 10:29 PM
augi's Avatar
Default p0403& p0404
I know the codes stand for egr valve and solenoid, but does this mean the solenoid is measuring bad flow or the solenoid may be bad? Can someone educate me on the egr valve of these cars? How to test/ clean the things that cause this code to fly?
My car intermittently throwws the codes, sometimes the cel will go out for a couple of days and come back on.
Id like to just learn how to bypass it if at all possible. I know on my old car it was vacuum controlled and I just blocked off the hose and the cel never came on. I eventually put a block off plate on and forgot all about it. Is there anything like that to be done to this car?
Old Jan 27, 2011 | 10:20 PM
augi's Avatar
update:
Thanks for the help guys
After MUCH research, I have foiund that if you want, you could weld the pipes for the EGR shut and program it out of the computer.
Thats to delete it.
to clean it, you can simply spray OODLES of carb cleaner in the piping for it and bath it in carb cleaner, take a pipe cleaner and scrape it out. (being careful not to get any on the electrical connector)
after about 45 mins of doing so, its golden.
Old Jan 27, 2011 | 10:23 PM
KJRich's Avatar
Originally Posted by augi
update:
That's what we're here for!:p
Seriously though, glad you got it figured out.
Old Jan 28, 2011 | 05:42 AM
biggriggs's Avatar
If you had access to a tuner, you wouldn't even need to weld anything to keep the EGR valve shut. You could just set it to never open basically. Doing this, or deleting the code reporting is illegal in most places though (as is welding the EGR shut, running blockoff plates, etc).
Old Jan 28, 2011 | 09:39 AM
zipper's Avatar
Sorry augi, missed this thread. I'm glad to see though that you found the answers you needed. If you don't want to weld anything or fab your own block off plate, you can get the plates from ZZP here: http://www.zzperformance.com/grand_p...=229&catid=110
Old Feb 5, 2011 | 10:50 PM
augi's Avatar
Alright... I know I said I figured out how to block off the valve, but how would you go about cleaning it? I currently don't have cash to purchase a tuner and would like the cel to go away... help?
getterdun
FWD Tech Guides '95-'07
Oct 17, 2016 03:49 AM
Victory
Aug 8, 2013 10:40 PM
dustybird3
Feb 5, 2008 08:18 PM
victoryred05
Jan 10, 2007 02:45 PM
king2805
Jul 14, 2005 10:34 AM
